problems with #1 and #2 suggest a air flow distribution problem not a fueling problem. Alky injection follows airflow distribution until inertia skews that relationship.it was #2 for me last time![]()
SignUp Now!problems with #1 and #2 suggest a air flow distribution problem not a fueling problem. Alky injection follows airflow distribution until inertia skews that relationship.it was #2 for me last time![]()
I believe the issue is weather related. Almost all the #1 and #2 issues with ALKY occur during the winter months. When it's cold outside, and you're running on the edge, the ALKY falls out of suspension, when this happens the air going to the front cylinders is "dryer" than the rear. I have personally logged inlet temps in the 30*F range during the winter months. If the inlet temps fall below the 70* range you run the risk of running lean in the front cylinders when injecting lots of ALKY.
the tune is to blame.
You don't have to crank the gain to have problems. It boils down to GPH vs IAT's. A balancing act if you will and we have no control over IAT's. If there is a 40f drop overnight and the car is tuned for 70f weather there is going to be problems no matter what. There is just no way to control distribution. Even with a single nozzle ultra low IAT's will starve the front cylinders. You may not get the meltdown with a 70%-30% tune but your chipping away the gaskets on 1 and 2. I've experienced it first hand.
Bottom line here the intake is not made to distribute liquid fuel(.) Not slamming alky or alky control. It's a great product but there is a problem and from your post above you are aware of it. It would be in everyone's best interest to work toward a solution instead of posting the same old spiel........
OK the tune is to blame. Then why aren't the back cylinders getting torched?
