Got my GN back on the road finally, had the engine rebuilt (minus machine work since it was still in stock specs) along with ported/polished 8445's and a roller cam, then had a few headaches with a Hydroboost swap. Got about 500 miles on the car and I've tried a few WOT runs, haven't recorded with PL yet, but it feels like the spark is being blown out at 21#, this is through the mufflers. It has more surge if I open the cut out and the boost goes up to 23#. WB O2 is showing anywhere between 11.5:1 to 12.0:1. No Knock. Plugs are NGK UR5's gapped at a tight .031", same plugs and same gap as I had when the longblock was stock running 28#.
