Ok.. time to move.
Set of ported TTA 6702 castings with epoxied runners to improve flow. These are extremely worked heads. Probably one of a kind. Have the big stainless valves. No disappointments.
Ported TTA intake manifold with EGR removed/blocked off. Tons of labor went into this piece. Port matched to the heads.
Kenne Belle polished plenum and 70 MM Throttle body. Fuel rail included. Top end of motor should easily take the car deep into the 10's. setup with a 70 turbo went 10.7's at 128. Set of Comp 941 springs included. You will need to set spring heights for your cam.
serious inquiries only. Will only sell intake/TB/plenum after heads have been sold. Should all go together really.
Complete setup 1750.00
Heads like these are easy 2K, plus intake, plenum, TB..add it up
Cheers..
Cheers..
