dank GN
BlackArts Automotive (661)993-8277
- Jan 11, 2009
I just wanted to show everyone some pictures of the porting I did on this turbine housing. If you want your turbo to not have issues like boost creep ,surging, ect it’s wise to match up your flap on your downpipe to the wastegate hole . Basically what I did was smear alil grease on the flap then bolted it up to the turbine housing. Now that I had the relation of the DP flap to the turbine housing I made another circle that I could port out and still have the flap covering it .
