derekajones
- May 14, 2010
Hey everyone. Car started running funny late last year and Havnt been able to solve problem. Any help would be appreciated.
The car idles a little rough, has a hard time taking off from dead stop like a stop sign feels like it is about to die. Car boggs down under turbo load. Engine seems to work well. Put a fuel pressure tester on and most I can get it 30psi it will lower when adjusted but won't go any higher.
Since issue I have: replaced plugs. Replaced fuel filter replaced fuel pressure regulator. Replaced MAF. Took injectors out and had cleaned and tested. Replaced all vaccume lines. And just general maintenance
All items I was going to replace any way because of age
Next step will be to replace fuel pump but is there anything else I could be overlooking? The fuel pump is hardwired to fuel pump. The car is pretty much stock with a turbotweak stock chip installed.
Thanks all!
Thanks all!
