turbo nasty
Turbo Dojo / MNTR
- Jul 19, 2001
Ran 24-25 ish psi for years on the stocker...93/alky. New engine will be low 20s for starters
SignUp Now!Not a good definition by any means but it is manifold pressure and nothing more than that. Mass flow is what's getting in.
30.4 is the max for a 3 Bar right? I wonder what it was in reality.
ZNix said:That is on 93 + Alky right? Or is that C16?
On a stock cammed/headed engine it will keep making power till you hit 52-53lbs/minute. Probably happen with boost in theZNix said:Not that I want to turn it up that much because 25 is going to be a handful already, but would a set-up like mine be able to push 30 PSI at the track? Or would that be asking for a disaster? I think the 6131 would probably be about out of breath by then anyways. 93/Alky stock heads, cam, 980 springs, 6131 Turbo 3" DP, 42.5lb injectors, razor's alky.
Chargebacks@ipaymentinc.com lolLittle fun earlier today, looks like I am getting some boost creep again.View attachment 158821
29.4 is 3 bar. Actual was probably 32-33psi
