Postons GN107T cam specs
TurboDave
RIP DAVE
Staff member
TurboBuick.Com Supporter!
Hello folks. I recently acquired a new Postons GN 107 T cam, but without a card. I've searched until blue in the face and have only found a couple of tid bits of contradictory information.
Anybody have an old cam card for one of these layiing around, or actually know the specs???
TIA!
Postons GN107T Cam
This is from Poston's 2008 catalog, hope it helps:
Camshaft Grind: GN 107T
Cam Type: Hydraulic
Lobe Center: 107
Advertised Duration Intake: 254
Advertised Duration Exhaust: 254
Duration at .050 Tappet Lifting Intake: 202
Duration at .050 Tappet Lifting Exhaust: 202
Valve Lift Intake: 430
Valve Lift Exhaust: 430
Power Range: Idle-5600
Maximum RPM: 6000
Cam Type: Hydraulic
Lobe Center: 107
Maximum RPM: 6000
That's what I was looking for!!! THanks!!!!!!!!!!! Sounds like an ideal candidate to go back into a stock rebuild like I'm working. Putting my numbers matching engine back together to go back into my 86.
Also sending it out to Richard's for paint in a couple months.
That's what I was looking for!!! THanks!!!!!!!!!!! Sounds like an ideal candidate to go back into a stock rebuild like I'm working. QUOTE]
Also from Poston catalog: "Ideal cam for stock engine. Compatible with stock computer...Works with stock torque converter...compatible with stock or upgraded turbo... Easy 12 second cam with minor upgrades. Keeps exhaust velocities high to enhance turbocharger spoolup".
Glad I could be of some help :)
