I rebuilt my power antenna.. cleaned it out, burnished the stator where the brushes make contact, lubed it good, put in a new cable and it worked great...
then i was troubleshooting my cruise control circuit, had the cruise module disconnected and noticed the radio filter connector that goes into the "BAT" terminal on the fuse block was loose, I have the power for my radio tapped there..
I was trying to get the connector into the fuse block better, but as i was doing this, my radio was switching on and off, simultaneosly switching the antenna up and down...
well, i finally got it in, the antenna was up.. and now won't go down.
the relay clicks, and I checked for voltage and it is coming in at the relay.. i tried hooking up a 12vdc batter at the antenna to operate it directly, no dice
Did the self-resetting circuit breaker crap out? the motor die..?
Also, after all this happend, i went to test drive the car to test the cruise control, which now works.. and i get a code 31 for the wastegate solenoid.
ugh.. any ideas?
ugh.. any ideas?
