TurboWh1
- Aug 12, 2002
I have a odd situation.... the 30a fuse blew on the last drive in my GN. The power master motor was making a humming noise, none like I’ve ever heard. Motor was very warm to the touch. This went on for 20 minutes or so. I was being extra cautions as I was assuming the brakes were about to fail. No brake light was on when the motor was humming. The Brake light finally came on and I had about 10 stops left. I ended up limping the car home. So I replaced the 30a fuse and the motor started working. At First, the brakelight was still on. So I replaced the accumulator and brake switch with known good parts. The power master seems to be working now but not as I feel it should. The brake light is off and there are no external leaks but the power master runs every time I hit the brake pedal. Roughly 2-3 seconds. The brake light never illuminates on or off the pedal. I don’t feel this is normal. Anyone ever experienced this? Motor bad or internal failure? I’ve reviewed the info on gnttype.org. My scenario doesn’t fit the flow chart.
