20psiofevil
- Feb 10, 2013
Is windage and crank case vacuum the same thing? Or is vacuum a byproduct of windage? I understand that a crankshaft spinning at high rpm is moving air inside the pan doing all sorts of crazy stuff. Would one benefit greater from a windage tray or adding a vac canister?
On a side note I hear a proper setup canister is worth .2 on the strip? Anyone have similar results?
