Power Steering Pump - Aluminum Pump from Another GM Car?
One more photo of powder-coated reservoir. Pump and reservoir are quality pieces! Reservoir has a baffle in it. Also included photos o Lee 625 box.
Conrad
They are AN fittings. Neat caps...huh?
Conrad
Look like AN fittings with caps. got a cost on that unit ?
Higher output than stock to run a Hydro unit ?
This one has been dormant, what application/year LT1 pump worked, and any in service updates on the Jones unit ?
I don't need a reservoir, just a good pump with -6 lines.
also, care to share costs ?
every LT1 used the same pump- so get one for a 92-96 Vette, a 93-97 F body, or 94-96 B body..
but i don't see what the benefit would be, since they are probably the same pump as a GN..
If they are aluminum, I suppose guys are looking to save a pound. Or possibly a cheaper alternative to the originals?
Aluminum body pump from Turn One. Upgraded so that it can be used with a hydro boost.
Yes you need to call. They need your old pump or a core to pull a few parts out of. The thingy that allows it to pump in reverse is not made anymore.
Thanks, I knew I saved spare for a reason !
What was the approx. cost ?
I talked to Lee Power Steering on Friday. They can put the reverse rotation guts from a GN pump into a new aluminum housing (or rebuild the iron pump). No idea on price yet. They're just getting back on line.
Glad to hear they're opening back up. They rebuilt my iron pump and increased the flow for hydroboost for like $150? Also added AN fittings. Good people.
