Powerlogger - only registering analog input
JW87T
SilverT
Just installed Powerlogger, and it seems to register the analog inputs from the EGT adapter and 3-bar MAP, but that's it. Monitor shows no rpm, no O2 volts, no MPH, etc. Install seemed to go OK. Got two sets of 'hardware detected' and installed two drivers. Using TurboTweak chip, and I specified 255 for MAF.
Could this mean a bad connection and I need to reclean the ECM connector?
yes
also try not plugging the PL onto the ECM all the way, back it off a tiny bit
Bob
I moved the PL around a bit, and it connected, so that worked.
Thanks!
It's crazy the speed that it registers changes. Blip the throttle and it shows the TPS change, etc. immediately. See it changing BL cells. I am used to maybe 10 frames per *run* with the Turbolink, not 17 frams per second.
Great product.
I noticed the green led on the PL blinks when it is connected, like a router polling. Guessing this is normal. I read the install instructions again and can't see where that is mentioned.
WB o2 next.
