SignUp Now!It is the same pedal.
OK now BWEAVY thinks the vacuum pedal is the same for a HydroBoost. Hasnt anybody done this that can verify? I'm going to make a poll in the brakes section!!!
I did the Hydroboost conversion on mine and I was told to use the stock Powermaster pedal. It works great. The Vacuum pedal has a different pivot point. That is why you either have to drill the Powermaster pedal or use a vacuum specific one to convert to vacuum. When you buy a vacuum kit most will include a pedal for that reason. I installed a pretty expensive conversion, but everything bolted up to the stock Powermaster bracket with minimal grinding. I also used an aftermarket reservoir.
Dont mean to jack your thread but its somewhat relevant and im hoping someone may have what i need. I am converting to vacuum brakes and i need the pedal for the conversion ( its different from what i read here, the pivot point) anyone got one for sale??? mounting bracket should be the same correct??
I bought the kit from PowerbrakeBob Power Brake Services.com.
He is not a supporting vendor on the board.
Be warned. There has been plenty of controversy over his after sales service. Some are are really unhappy. I did find the reservoir needed some slight alterations to stop it from making noise and the supplied lines could have been better quality for the price. Other than that, the kit works great for me and haven't had any other problems so far.
