SignUp Now!You are running the mph for 10s Just need a 1.52 60ft
What fuel are you running? Are you giving it more fuel through the chip to compensate for the extra boost? Nice job, with a converter, you will be in the 10's.11.1 @121......it nosed over real bad at the 1000ft mark and I looked down and 14* of knockIt was missing pretty bad after...... I'm hoping head gaskets.
All my fault, I always watch my gauges and after I sat in the lanes for over an hour waiting for track cleanup I was just anxious to run.
I swapped from a 6262bb to a 6266bb and figured I would get a little more lag. The 6266 spooled quicker in my opinion. The 6266 is insane on my stroker engineDrove my car today for the first time with this 6265.... Put it in my inlaws garage till the Buick event next month....Did not go full throttle but this thing seems to spool up quicker than my 6262 did....It was pulling good at just part throttle, so can't wait to go to the track to see what this thing does..The turbo swap is the only change made to the car....
Good to hear!! Haven't driven my car in several months and not sure if I wasn't use to the power compared to my daily driver....Do you have any track comparisons of the two??I swapped from a 6262bb to a 6266bb and figured I would get a little more lag. The 6266 spooled quicker in my opinion. The 6266 is insane on my stroker engine
No track time comparisons but my car definitely feels stronger in the mid range and top end. The bigger turbine really helped with my 252" engineGood to hear!! Haven't driven my car in several months and not sure if I wasn't use to the power compared to my daily driver....Do you have any track comparisons of the two??
Ya I could see where with a stroker you would benifit....I won't see the difference you will cause I'm not pushing near as much air....I hope to be able to see a little gain and run consistent high tens...Thinking that my 6262 turbo may have not been right from the start!!No track time comparisons but my car definitely feels stronger in the mid range and top end. The bigger turbine really helped with my 252" engine
