So cal which one did you set me up with 63 or 85I guess i should fined out
thanks for all your help cal very knowledgeable you have helped me out many times.
63 for your combination
SignUp Now!So cal which one did you set me up with 63 or 85I guess i should fined out
Why don't they just make them bigger from the factory has always been my question. What applications is the tiny wastegate hole good for when it comes to controlling boost?
some people run an internal wastegate maybe?
Making them larger would make them unusable on some setups. You can't easily replace the material that's been removed once it's gone. Measure twice and cut once. Also when running the turbo hard you need the hole smaller or the backpressure will have more surface area to push on which will require much higher wastegate spring pressures or external pressure sources to get linear boost.GetOwnedVette said:Why don't they just make them bigger from the factory has always been my question. What applications is the tiny wastegate hole good for when it comes to controlling boost?
66P said:Okay, I will do the normal hole enlargement maching up to the normal puck and see how it doesThanks Bison.
66P said:That's a good idea Bison. Thanks for sharing thatI will try it. I wonder how much faster this turbo is spooling? My tnetics 66-p-bb-63 is old technology and it has a cast wheel. I guess I'll find out, turbo should be here Thursday. I ordered 80 pounders to go with it. I had 60's in it.
I was told I might need the extra fuel.
It will spool considerably faster. .
Can you get one in a 4 bolt?
