precision H versus S inlet
DGC
Senior Member
Are there reasons to go with the smaller (S) inlet versus the larger(H) one?
Most of the blogs recommend S but is there a danger of mating a 4 inch
cold air to the 3 inch turbo? I already have a 4 inch and was planning on the
H cover, but maybe bigger is not better?
Thanks,
DGC
H is 4" in , 3" out Its BIG and makes sense for front-mount intercoolers only.
S is 4" in, 2.5" out and fits with big-neck stockers, and the stock location PTE intercooler.
E is 3" in, and 2" out which matches the stock in and out sizes.
Bob
(I run the S)
The only major benefit would be if you were running high boost levels, as the H cover would give slightly cooler charge temps vs the S cover. Most Buick owners don't typically reach that boost level or warrant needing the large H cover. (IE: 29psi and faster than 10 flat range) The S cover is plenty for almost all applications. The H cover does have some alignment issues with stock location intercoolers. Also, there is nothing wrong with running a 3" inlet comp cover and 4" cold air system. I did it for years with no downsides. I also did see a difference in spool up characteristics and throttle response for the better.
HTH
Patrick
HTH
Patrick
At what point do these housings show a benefit? I have yet to see any difference in charge air temps on any of these when used with a decent intercooler and meth injection at engines from 550hp up to 800hp. All seem to fall right around ambient. Im thinking they would show a greater benefit in an application where the compressor would be at high speeds for extended periods of time. A lot of the diesel engines use this technology but it was never used on passenger cars to my knowledge.
