It was just for trouble shooting. A new cooler will be installed.
For a set-up to be that far off made me suspect. A similiar situation popped up before where a converter mysteriously tightened up 400-600 rpm overnightAfter a long talk the problem was narrowed down to quick couple fittings that were installed on the tranny lines. You know the fittings that look like an air hose fitting?? Some can be restrictive to cooler flow.
That clarifies it. The reason I asked about running without a cooler is that I have been plagued by a nagging little problem that I've learned to work around ever since I've had my vigilante. When cold, trying to shift from park into gear immediately kills the engine. I have to feather the throttle a little to prevent this.
I've always attributed it to the fact I'm running one of the old 7 disc models, and so many discs just don't have the needed clearances with cold fluid, even disengaged.
Any thoughts.
