priming oil pump
turk87
Can someone tell me if I have to use the vaseline method , or pour oil into the oil cooler line and roll engine or can I just unplug the orange ECM wire and roll the engine to get oil pressure? I'm changing my timing chain and hope someone can give me some advice....:confused:
Ron
Since the cover will be off, I recommend packin the pump with vaseline. This way you will disassemble the pump and check the condition of its internals at the same rime
Jim
