Aren't they pretty?Would you guys please stop DWELLING on this is issue.
Nice pistons by the way!
What is the stroke of the engine these pistons and rod are in?Was able to dig up this picture.
Sent from my iPhone using Tapatalk[/IMG]
......... I will say this tho. Stock stroke noninterference engine strokers are interference engines meaning that stock if something brakes less chance of hurting everything else! I.e. If timing chain brakes cam crank n rods should be ok. But if happens in stroker crank will hit and brake cam!
3.59 stroke with 6.5" rod. Based on the measurements they should work with a 3.625 stoke and will bring the piston closer to 0 deck. .What is the stroke of the engine these pistons and rod are in?
Aren't they pretty?
I had this same reaction to a direct drum that Bruce at PST Extreme sent me years ago. I told him that I didn't want to put it in my transmission because I though it belonged on my fireplace mantel.They are, and if you have six of them laying around you could send them to me so I could put one in every room so I can admire them all the time.
Do you know the compression distance?Was able to dig up this picture.
About 1.209"Do you know the compression distance?
The stroker motors I have seen have held up good.it's in the tune and how well the motor was built.I have driven alot of these cars there is plenty of extra cost in a stroker that only seems to be slightly more responsive on off boost driving.the motor stroker or not will make nothing for power anyway until it's well into boost.Interesting thread. I'm currently having my block machined decidingredients if I should go stroker or not. I definitely want it to be very reliable, not sure how that would really get effected by a stroker setup.
Not sure if it's true, I believe someone posted in this thread the long rod stroker pistons have shorter skirts which would make the piston more likely to rock in the cylinders? Also the fact the wrist pin is in an oil ring?The stroker motors I have seen have held up good.it's in the tune and how well the motor was built.I have driven alot of these cars there is plenty of extra cost in a stroker that only seems to be slightly more responsive on off boost driving.the motor stroker or not will make nothing for power anyway until it's well into boost.
Just one of the stroker 109s that made 700rwhp up here runs pretty good and has been together for years.pump gas alky car.Not sure if it's true, I believe someone posted in this thread the long rod stroker pistons have shorter skirts which would make the piston more likely to rock in the cylinders? Also the fact the wrist pin is in an oil ring?
So these things aren't real issues? The cylinder bores and pistons will last just as long as a stock stroke assembly?
The block itself isn't more likely to split/Crack when pushing the setup?
It sucks I can't see signatures on my cell phone.Just one of the stroker 109s that made 700rwhp up here runs pretty good and has been together for years.pump gas alky car.
I prefer not to advertise my personal cars combo but the car I mentioned is a car I have driving experience with but don't ownthe car has a twin nozzle meth kit from alkycontrol.It sucks I can't see signatures on my cell phone.
What kit are you running? Sounds like an impressive setup.
Haha, I was meaning what stroker kit but if you can't tell, that's alright.I prefer not to advertise my personal cars combo but the car I mentioned is a car I have driving experience with but don't ownthe car has a twin nozzle meth kit from alkycontrol.
Not sure on that one but I will tell you a stock stroke 109 up here has been right past the stroker 109 with less partsHaha, I was meaning what stroker kit but if you can't tell, that's alright.
