Re: cost
Originally posted by TRFanatic
Do you mind if I ask a ballpark price of the Willwood front brakes??
Thanks alot,
Ravi
They were $624 from Summit.
Everything is included in the kit, you just have to get the spindles machined a bit.
That's pretty much the standard list of stuff people recommend you do. Its adequate for a street driven car, but if you're racing (SCCA Solo, open track events, whatever), there are some items in there that could actually kill you.
The biggest issue is the rear suspension. Once upon a time, I believed the "poly everywhere" bit. I've even made some pro-poly posts on here.
I take all that back. Installing all polyuerthane bushings in the rear is suicidal.
Read this:
http://corner-carvers.com/forums/showthread.php?s=&threadid=9237
Couple posts down. For background, Corner Carvers is a low-BS forum heavily populated by NASA American Iron racers. Mostly a Mustang board, but the Fox body has a very similar rear suspension to ours, and a lot of their experience carries over.
That bind study shows all-poly bushing cause incredible amounts of bind. I had all poly in the back, and learned the hard way at an autocross that it wasn't a good idea. Snap oversteer exiting a very tame slalom followed by a 30 yard powerslide (stopping 6" short of a curb, no joke) almost ruined my underwear.
I just came in from the garage. I replaced the poly at the chassis side with OEM rubber.
Another issue is the ATR rear bar. Its nice if your rear springs are shot or you're drag racing, but it is my opinion (no testing data, just an opinion) that the stock bars are more than adequate. I fear that huge ATR bar will limit the ability of the rear end to articulate. Fix the roll with springs.
Another Correction, while I'm typing, I've bailed on the UB Machine arms. I got a fully adjustable set from a guy on the MonteCarloss.com board. They should introduce a negative camber curve, and they eliminate the need for shims to do the alignment. I'll have complete control over static camber and caster.
Here:
http://www.montecarloss.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=18;t=001272#000000
HUGE thread that started with a bumpsteer question and turned into the most comprehensive discussion and analysis of the G body front suspension I have been able to find.
