Ok can some one help me with this PT67GTQ NON BALL BEARING turbo. Should I keep it or I was wondering if I should go to a pt6776 bb turbo with the 4" inlet and 3" outlet??
Here is my new combo with a stock block that is going to be refrenshened up with this:
* TRW pistons .30 over
* stock rods
* stock crank with billet main caps
* Champion iron proted heads with stock rockers
* Cometic head gaskets from Weber with ARP studded head bolts
* Champion ported intake
* Accufab dog house and 70mm throttle body
* 206/202 Weber roller cam..not a high lift 206/206 cam
* Weber front cover with high volume oil pump
* light wieght LT1 starter
* Quad Air dual intake pumps
* Quad Air volt booster
* Caspers hot wire kit
* 72lb injectors
* stock computer modifed for low impedence injectors
* brand new- Turbo Tweak chip for 72lb injectors
* brand new- stock AC Delco stock mass air flow sensor
* Precision front mount intercooler
* ATR headers
* 3" THDP
* brand new- Julio's dual nozzel alky kit
* 4 core raditor using stock end caps with Ramcharges dual fan and dual relay from Casper
* two air bags
* ATR rear saway bar
* boxed in lower control arms and both up upper and lower control arms with new bushings
* S10 wheel cylinders..can hold 15lb of boost on foot brake!!
* Hurst line lock
Now I am sending the PTE stall converter to get it tightened up do to realized it is too lose. ITS LIKE AT 4000 . Lasalty I am using a BUILT 200r4 from Jimmy's Transmissions in Illinois...HE DOSE GREAT WORK!!!!!
#### SO ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED ON WHAT TURBO SHOULD I USE....
Thanks!!!
Rod
* stock rods
* 72lb injectors
* ATR headers
* 3" THDP
* two air bags
* Hurst line lock
Thanks!!!
Rod
