Bob, I am measuring it right at the turbo outlet. I have a weld bung in the intercooler pipe after the connection. The intent was to measure pressure drop through the intercooler. It came in handy to try and get a idea what was happening to cause the blade to fail. After this pass, I noticed a little higher idle. The next pass it failed on decel. I overwrote the data on the return road messing around with the car. It would have been interesting to compare the two passes.
If I'm not mistaking the BOV should be open(ing) around the time the spike happens. Another lessen learned is maybe ease out of the throttle if you can, that might also help out, but who's thinking about that while you are worried about stopping.
The throttle body was a Holley with a billet AL blade. Not sure if it's a little more prone to bend than the other type of material, but the bottom line is it finished my year up a little early.
