hands on gt42 today...
got a chance to physically go over a non-bb gt42 today at MPE. Its quite an impressive unit and not exactly comparable to anything else out there.
The compressor/turbine wheel design is different from anything else. There are also various tweaks that can be done on the inducer side, involving knife ending the inlet edges.
The inducer inlet has channels cut into it that the compressor wheel draws air through from the massive 5" compressor housing inlet.
Right now all true GT turbos are 4-bolt exhaust housing. This 42 has a 4.8" v-band exhaust outlet. The compressor outlet is also v-band style (4.2"). The compressor backplate is cast iron. The center section has a serialized plate on it that has "Garret GT" on it.
The 42 is psuedo equivical to a non-bb T88 in terms of spool, but output is aparently higher. The 42 I looked over has a 82mm compressor wheel.
While I didn't get to check out a GT60, it is a 2200hp capable turbo and is bigger then the T106, and has a 141mm compressor wheel, that's 5.5"
The retail on it is over $4k
I had my digital camera with me, but didn't take pics.. hey, its just a turbo.. i've seen tons of them
