On stainless steel brake lines I bought from Inline Tube, they install the OEM-looking coil spring around the SS tube. The coil spring is zinc-plated steel, but in time it will rust.
What was the purpose of this commonly used coil spring? It's sometimes called a "protector", but the brake lines already seem so well protected from errant stones, I can't imagine much benefit.
It won't look absolutely OEM and "correct", but am thinking to cut off the coil so that the stainless lines' appearance won't be compromised by a rusting steel spring.
