Phoneguy
Cometic HG stress tester
- Aug 27, 2002
Just looked up those plugs and they are extended tip. The AR3933 which is a non projected tip will work nicely with the TA heads .I forgot to get you that info.
NGK UR5 plugs gapped at 30 I believe?
Chip timing was 23/21
I was just on TA Performance website looking around since I'm going with their heads. Lot's of cool stuff over there.![]()
My compression is higher than yours is. I ran 20 degrees of timing across the board in BG to get the times in my signature with lousy 60 foot times. I have a little room to play with the timing down low to help but will probably leave it at 20 up top. It's a work in progress. .
Bryan
