I know that pulling the motor and rebuilding it would be the preferred solution, but due to time and budget constraints I just need to get a little more life out of the motor for the time being.
Anyway, the 87 GN that I recently bought (with 105K) has a rod knock. The guy who sold me the car stopped driving it after it suddenly developed an oil pressure problem. I put in a Melling kit last week and although I get 80psi when the motor is cold, I'm only getting around 5psi when it's hot and idling in park.
I ruled out loose torque converter bolts because I disconnected the spark plug wires one by one until the knock went away (it's most noticeable at around 2500rpm).
I've decided that I'm going to pull the pan and if the crank is okay, I'm going to swap out the bad bearing.
The questions I have are as follows:
- How do I determine which size rod bearing to use?
- Since I'm going to rebuild the motor soon anyway, do I need to worry about the other rod bearings and/or the mains right now?
- Is there anything else I should do while the pan is off?
I've done a similiar thing with my 70 Chevelle (many years ago) when I had to swap out a bad piston so I'm not afraid to tackle the job. My biggest question was just trying to determine which size bearing to use because I noticed that the parts places sell them in several different sizes.
Thanks in advance,
Christopher
Thanks in advance,
Christopher
