Over the last few weeks, the car started making a few odd noises (presumably because it had sat fairly dormant for so long before I bought it). The first was a squeaky belt...easy fix.
The next noise started out as an intermittent tapping from the accessory drive region. Over the course of 2 weeks, it went from a "tap" to a "squeak". Tonight, I tracked down exactly what it was.
The crank position sensor was rubbing a bit too hard against the pickup points behind the damper. With the car idling, and the squeak present, a shot of TB cleaner eliminated the squeak for a minute or two. In light of this, I loosened the bracket that seems to hold the magnet in place and very slightly nudged the magnet back in the bracket...maybe ".015-".020 at most.
The car fired right up and idles fine, seems to run fine and I can detect no ill effects.
My questions are...
Is there a spec for the gap on the CPS? Should I throw a feeler gauge in there and more precisely adjust it tomorrow? Did I dramatically alter the rotation of the earth (or the performance of my TR) by doing this?
Thanks!
S.
My questions are...
Thanks!
S.
