Hey Guys,
I have an '87 turbo t. Have all new front suspension with urethane bushings for the stock front upper and lower control arms and all the other front suspension components and urethane bushings for those as well. Would using the stock control arms with urethane bushings be okay? I basically wanted to stiffen the stock parts in the front of the car. My budget is kind of tight, but I wanted to do the best with what I could afford. What about running tubular uppers with the stock lowers with urethane bushings. Which tubular uppers would you all recommend? I have stock front/rear replacement coils, shocks, UMI rear upper/lower non adjustable control arms, UMI front frame braces and UMI rear shock brace as well. I read something about running using the tubular uppers and stock lowers together somewhere on one of the G body forums. Any information or suggestions would be greatly appreciated.
Sincerely,
67gsconv
Sincerely,
67gsconv
