Lets put a stop to this
inlet hasn't been addressed.
Other than cleaning up the pockets and port matching, getting around that little inlet remains THE problem with a HA intake. They were only made for a short time because of this major design (flaw).
If you want to improve flow, start gathering up IC parts and give up trying to make this little pig sing.
Been there and done that, all you end up with is frustration and a lot wasted time and e$$ort...
Ahh.....yet another Hot Air skeptic destined to mislead the very souls that rely on him for advise. Covert, convert, or go to hell you sinners...lol:biggrin:
NEWSFLASH......Just because you couldn't make yours run doesn't mean it can't be done..."man that rhymes, now I'm a poet too." Many have already reached and surpassed there goals of making power with a hot air car. There are alot of fresh faces on this board so most of you don't remember when the hot air section was full of innovators and guys that actually researched and tested their cars at the track on a weekly basis. Back when Turbomotion, 0 to 60, Eastern Performance, ATR and a few others had parts to support our vehicles and we gave the feed back on them.
They have gone the way side and there are but a few of us still around but they will be missed. So I will give a shout out to those that have left us, "the real hot air innovators" Buickfromhell, twins, nocooler, herbfisherman, cool84,TType84, 6Sense, LeeThompson, turbo6X2,redshotair, drewcarlton and a few others I can't remember off hand.
When these guys where around this board was happening with R&D and not just talking about it but "DOING IT" and giving out good solid advice. Not the usual give up and convert. There have been pleanty of hot airs with 11 second time slips, now I don't know about you but 11's is fast in my book. It seems that the real limitation to these cars after you replace the passenger side header is.
1) The Intake Design
2) The limited availability of an aftermarket turbo.
As far as the intake is concerned a stock one with a good port job should do fine down to the 10's as stated. Lee Thompson ran 10's non intercooled with a stock ported intake. What most people don't understand is the intake was designed with 2 purposes the long runners create torque. It gives the intake a tunnel ram effect without the additional height that would be required. Also they where originally designed to be used with a factory installed alcohol injection system that also takes advantage of the long runners giving the air time to cool before going into the cylinders. The only reason buick switched to intercooled so soon was because alcohol just wasn't feasible for use by the general public without having massive warranty issue from people blowing engines because the alcohol ran dry.
With the turbo the lack of carbon seal backing plates has been the drawback from being able to go any bigger than stock. Since our cars have a draw through design the dynamic seal turbos simply won't last long on a hot air.
So please stop spreading misinformation and discouragement about theses cars and help to preserve the few that are left. THE ONES THAT STARTED THE REVOLUTION.......THE 84-85 TURBO BUICK.
WITHOUT US THERE WOULD BE NO 86-87'S.
I'm done!!!!!
