Questioning turbo size
Not good thinking 1.9 to 2.05 second if I remember right.
need a converter and boost leave the turbo alone.with seat time and traction should run low 10s/high 9s depending on weight and hook.the bb turbo change will spool faster but you need a looser converter period
With the trans brake it will only stall to 2500 RPM but the boost will hit over 20 PSI.
No matter it leaves the line lazy and spools slow.
is there someone around you that works on or knows about the turbo buicks?maybe take a ride and see or log it and send it out or post up
Need to make some more logs as I have other changes.
Most importantly changed the alternator pull so I went from 12.4 volts on the system to 14 volts.
When I got the car someone put an underdrive crank pulley on it but still had the stock pulley on the alternator.
