Ok, I'll rephrase... You're driving down the road. You're 10000 miles from the nearest methanol refil station... cuz you know, they're on every corner. And the bucket that contains the methanol you use for your alky injection kit, runs out. As in, while driving, it became empty, by whatever means you can imagine. Now..... after this alky jug becomes devoid of all alcohol, or methanol, what do you do. Stay out of the boost... right. And I'll cruise at 11 mph allll the way home, while NEVER soo much as even passing someone. THAT'LL happen. How do you pass without pressing the throttle down quickly? How do you pull out into traffic? I can tell you this, if you wanna get home from work, in detroit, you have to depress the throttle, period.
So now what electronic, physical, or even mental, emotional and/or spiritual changes must I make to my car, to be able to run it, now that the alcohol's all gone. Am I correct in assuming that you just turn the psi down to whatever your car can run on, with the octane you just threw in there, and that's it? Or what. I'm guessing that when the little "empty container" sensor is on, the alky pump get's shut off to prevent wear/damage? But now, will your tune be way off? Will you have to screw with the timing as well?
What's the scoop.
