SignUp Now!How'd you come up with 14 degrees Donnie? I figured you try for a little less than that. Maybe around 8-9 degrees.
On final assembly, I'm going to tack on the ends of the screws, or just tig it enough to melt the ends so they can't back out.Stainless on stainless, both the same alloy, is the worst for galling. Stainless on mild steel isn't nearly as bad. Oh, going from 100F to 500F with a 3/8" 316SS shaft and a 3/8" hole in mild steel the clearance will shrink 0.0005" (half a thousandth), plus whatever warpage occurs
. I still think tacking the plate to the shaft in two places would be better than screws.
I found an actuator that requires 31-32 psi to fully stroke a distance of 5/8". It makes for a very short lever. I'll be using CO2 pressure to stroke the actuator and close the spool valve, while the same pressure source opens the BOV. When the pressure is relieved, the BOV will shut as the spool valve opens.
All that's left to do is make the bracket that will hold the actuator to the adapter flange.
Can I ask....what 's the purpose of using CO2? Reaction... like being able to apply peak pressure before the engine gets to full boost?
