Going to run water with rmi once the temps stay above freezing here in the northeast. Ive been doing some research on this and cannot draw any sort of conclusion on the subject. Some real race cars use 29lb caps, but if my car never sees above 190* is there any reason not to run a zero pressure cap? Ive pushed a little coolant into the overflow when i topped off the radiator, obviously when liquid gets hot it expands and has to go somewhere. I've also pushed headgaskets into the coolant jacket which blew anitfreeze under the car doing 120mph at the track and almost kissed the wall. Some also say that you need pressure in the coolant system to prevent caviation, but too much will cause it. I've also heard that pressure is required when running water to prevent vapor pockets around the cylinders which (at the very least) can cause detonation. Im using a 16lb cap right now.
Anyone got the straight poop on this?
