MattSwindle
- Aug 15, 2005
first off..
are you always able to reach ambient on the ait's..?
If so, is going above 25% fueling reccomended to get there..?
(combo..'97 T/A..LT1..D1 (sc) non-intercooled..dual nozzle Alky-control set-up)
2nd..
verifying the controls..
the way I understand it..(am I right?) and related questions..:
A>>the pot identified as "TURN-ON" sets the starting voltage "INPUT"
from the MAP sensor..(instructions say 1.7 to 5 volts)..
on a 3-bar MAP the 10 o'clock postion is approx 4 psi..?
adjusting this pot CCW lowers the input voltage it's looking for, to bring
on the system at a lower boost level..?
B>>the pot identified as "INITIAL" sets the starting voltage "OUTPUT"
to the pump motor..(instructions say typical starting output voltage is 1-3 volts) generally the starting position is the 11:30 position..?
adjusting this pot CW increases the amount of voltage to the pump when
it comes on at the TURN-ON's setting for boost level..?
this is only for setting the starting point or rather for the starting voltage to the pump?
C>>the REMOTE KNOB/"PUMP GAIN CONTROL" adjusts "output" voltage by
affectively multiplying the "INTIAL" 's output voltage by some %...?
what is the % of multiplication...?
is there a relationship of 0-100% in the full rotation of the knob..?
is the maximum pump output always going to be the voltage from
your charging system..? (for ex: 14 or 16 volts) Or does the controller set-up
a maximum output voltage internally..?
or does the remote knob amplify the output voltage to a percent above,
regardless of your charging system's output..?
Thanks Ahead!
Matt
2nd..
Thanks Ahead!
Matt
