Razor's update kit..
Steve V
Steve V's Automotive 757 560 2782
Got Razors kit installed and so far so good. Spark rattle/ping is gone. Haven't seen a trace of knock anywhere. 22psi with 23/21. I need to crank it up..LOL...
I have only 1 small issue. LED does not go green,I have dail at 6,pump is working,car is not knocking so I don't believe the pump is the problem. I may have wired something wrong. I followed all the directions etc,tripple checked.
Any ideas?:wink:
Digital dash car? Does your MAP sensor have 5V ref sig. and Ground? I had to run a ground and tap 5 volts from the TPS.
Stock dash. I am going to put air on the map today and have the wife watch the LED and boost guage. Maybe I don't have it turned up enough. 22 psi with a little alky maybe doable .................so guys run 20 psi on 93.
Figured it out..
If I had bought the kit new from Razor I would've never had these issues,I bought it used go figure.....
Anyways when installing the update,the thick brown wire from the little box goes to the silver wire on the pump. This wire is already grounded in the 1st design. You MUST remove the ground and just have the thick brown wire going to it. Now my led goes from red to green!:). My intercooler must be full of methanol.
