SignUp Now!Im thinking of staying with the original GM 8.5 to try and keep it looking somewhat original..just beefed up. If that makes any sence.Never had my eliminators leak. Wouldn't want them in a street only car. Would go ford ends.
-Auburm Pro Series 30 spline (8.5)Good luck with the build......
Not sure if it makes a difference, but all this is actually going into my 84 hurst/olds. Not my GN. I have a thing for g-bodies. This project should be an off body resto with and LS turbo. I've already purchased ride-tech's coil over full suspension and 14" bear brakes from a supporting vender. I would like to continue purchasing from venders who support this forum while building a good quality build. I just lack a bit of car knowledge and need some good guidance
Looks good. I would weld the tubes use the stock gear ratio
Who's Neal?Get ahold of Neal. Neal is a VERY smart guy.
Does it really matter what size of tire/rim size i have with the gear ratio?Looks good. I would weld the tubes use the stock gear ratio
Who's Neal?
But Motive Gear's website has 3 to choose from. Not sure which one to order
A-line serious -GM10-342A
Motive Gear -GM10-342
Motive performance -G885342
Could be application sensitive. Pure "race gears" are not intended to be used on the street. Might shoot them a note, and ask.
