Rear Frame Notch Kit
Can't wait to see it Lee! Which car are you notching the GNX? :eek: :D
I'll be buying this kit very soon. ;)
Here are the pics finally:
Thanks.
Rob
Turbo Buick Mods Home Page
What is the crossbar for?? Looks short to go Frame rail to frame rail?
Yes, the crossbar goes in between the frames to connect them. That bar is actually 45" long. I believe it's actually 43" from frame to frame. We purposely cut it a couple inches longer so the installer can cut it for a perfect fit.
does this Kit reinforce the inside and outside of the frame rail?Also where are you mounting the bar at?
Dennis
Dennis
Yes, it does reinforce both sides of the frame rail. The bar mounts in between the frame rails in the upper corner, in front of your spring perches.
Rob
would you sell just the two reinforcements on the inside of the frame.I have a frame notch alreadt and just want to add some more to it.
Dennis
Got a kit, pics would help my body shop guy to give him a heads up.
I have cruzn57 working on the install pics. It's fairly easy with the right tools. I do have instructions that come with the kit that easily explain. And if anybody have any problems they can contact me directly for more help anytime.
Rob
should arrive tomorrow ( tuesday)
I'll be doing it this weekend,
along with lots of pics,
kit arrived .......
I am removing gas tank, rear end, anything in that area, as I'm changing all of that anyways. ( 9in, and fuel cell going in)
I'll have the frame notched, and plates tacked in later today,
I'll post pics tonight,
