Rear Frame Notch Kit
Any pics of how the control arm brackets go or the bar?
And damn, the box said 60lbs of weight, what material is this stuff?
WILL HAVE MORE PICS TOMORROW ( fri)
I do have to work some times, LOL
will be completeing one side and starting on the other, including inner frame plates,
thanks
follow up
sorry for so long.
us old guys have to have a nap!
right side is complete,have started left side ,
learned a few things to make it easier,
here a few pics
planned???
you mean I have to put something there?? ( less weight?)
going to mini tub them, using inner fender I cut out, adding a 3in strip,
trying to make it look original ,kinda. but be able to have 13in under the fender. still have to run a rear down tube from roll bar to rear bumper support each side,
I'm reinforcing upper and lower control arm points too !
have 9in w/ 35 spline axles,disc brakes, pro gear, spool,wolfe anti roll bar, and the list goes on, and on.
should be able to handle twin turbo big block chevy, :eek: :confused:
Are these still available?
We have one kit left....and it is at close out pricing. I'll PM you the info.
We are no longer in the turbo Buick market and this kit is one of the last few items that we still have remaining for this market.
Todd B.
If anybodys interested. pm me. It will come with everything. All you have to do is cut your frame and weld in place. Will come with extra support plates. Still under development. We just wanted to know if it be worth making and selling them.
Rob
Turbo Buick Mods .com
Hi , have you come up with a price on your frame notch kit ? can you tell me on our stock GN rims how wide a tire can you get on with your kit ? hope this isn t a silly question , I run 275/60/15 tires , how much more rubber can I get on the road with your kit , Thank you Kelly
