Id loce to see the pics. This sounds like what TRZ is wanting to do for me, but they are still working on the jig in order to get these jobs in and out.
Pictures sent.
SignUp Now!Id loce to see the pics. This sounds like what TRZ is wanting to do for me, but they are still working on the jig in order to get these jobs in and out.
Kevin's kit wouldn't work with Louie's 9" with the high axle housing mounting location unless there was room on the brackets to add a few holes higher than the stock location. That would also make clearance with his roll bar more of a problem.
DW,
I run 295/65 MT DRs, they are just over 29in tall. The tire is so tall that it doesnt look that low but it is.
The pics were taken before I pounded out the most lower lip section of the inner fender well.Very nice job on those welds on the notch... I noticed you didn't bang out the wheel wells. Did you find you didn't need to do this?
The stance is not as cool as your white T, but it should work well for the track. I'll get a pic together.When I look at the artwork under the car, I can see where your bank account now is.Simply breath taking. You did a fabulous job. Any shots of the full car off the hoist? I would love to see stance.
what is the spring rate and length on those rear springs.
makes for lots of room back there!
also, does the location of the anti roll brackets on the rear axle make a difference? wider vs narrower
thanks
