Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
I don't remember the length needed but Home Depot's 1x1 is too short.
SignUp Now!My car is at the shop but if you stretch a tape measure across you could find out. Pretty sure the rear one just bolts on at the bumper mount.
Ok guys, this is quick and crude, but I just laid under the rear of my car and this will work and clear the gas filler.My car is at the shop but if you stretch a tape measure across you could find out. Pretty sure the rear one just bolts on at the bumper mount.
I would use 1/8 inch plate and 1/8 wall tubing. I use the Chassisworks.comPretty much what I had in mind.We have a large metal supplier in town but they don't sell to the public. I'll have to do some scrounging around to find some stock. I have a Grizzly bench vise bending brake that I think could handle the L brackets. How thick do you think the brackets and tubing needs to be?
Your up...This would be a nice project for the "fabrication" section.
If it hung down, it would be visible. Not many guys would want it visible. It would be really nice for those guys running glass bumpers on the street.I think it would be better if it hung down rather than behind things Donnie. If done right it could also be used to hold up the car on jack stands so you can do suspension work on the rear.![]()
They sell chromoly plate and tubing very reasonable. Do what I do and buy enough to make 2, and sell the other to a friend to make it cheaper for both of you.
If anyone one makes a second one similar to "Coach" design and wishes to sell it and if it does not require welding just bolt up, let me know.
Well I guess you could, but in my case, that won't work. My car sits with the nose about 3 inches off the ground, it has a downforce wing off the decklid, a 4 inch exhaust, and 12 inch wide tires on the rear...I think "sleeper" has long passed me by.If you did it right though someone might mistake it for a trailer hitch Donnie. That would add to a sleeper look and fool a lot of people.![]()
