- May 28, 2001
Made a proto plate. Drilled the holes w/o slotting them. [3/8"] The center hole is 2 1/4" dia. Plate is 1/8" hot rolled.
Here's a couple pics of the plate and it being on the frame.
If I made the inside edge the full length of the plate, it would allow the dr side to be as low as the bottom edge of the frame flange.
Note: The bolt pattern is reversed from the pass side. I am making the plates so there's no R & L. Just flip them over.
The flange on this first set will be tig welded on, as I want to be more accurate than using my plate bender.
The bar will be heavy wall 1" sq tube.
The fronts will be the same. All 3 holes will be used. [The 1 pic I saw of another bar, had only 1 bolt in the end...Y/N??]
Maybe, we can get REALLY trick, and employ some stress coat, and see what happens w/ a 25psi launch!
