SignUp Now!Prasad,
I'm am an engineer and I like what you did. Looks nice and clean. Congrats.
Conrad
Prasad,
I think we are a LONG way from having a "too stiff" chassis. I have not heard that from anyone whose opinion I would respect.
Have you thought about boxing the center part of the frame...currently a "C" section (under the passenger compartment)? I cannot tell if you have already done that or not.
I like the two bars that run longitudionally from front crossmember to rear crossmember along the frame in the middle. FWIW, the one brace on that long tube will only serve to stop it from acting like a long column (bending in the middle). It will not add any strength to frame. I learned in Statics class in college that any brace that is 90 degrees (perpendicular) to another brace adds no strength. Best run that brace at an angle to get some trianglation.
Comparing your photos to my GN...will the last round bar going toward the rear (one w/o "" bracing) interfere with your gas tank? Looks like it would on my GN....but I have an aftermarket (Ricks SS) tank. Have you tried bolting your rear springs and shocks to the chassis? Curious.
Great job! You should be proud of your work!!!
Conrad
WikedV6, i like how that frame looks. I would love to do something like that. What tubing did you use?
I used schedule 40 tubing from a metal supply store. I want to say it's a two inch but I have to double check. It's basically the same diameter as the tubing used for roll cages.
HTH
Prasad
Great tips on the PVC, I would have thought of that AFTER I did it, lol.If it helps, The key is to get the bar that goes across and over the drive shaft in place first then you can build from there. The body has to be on and off several times I actually made all the bends and pieces with PVC tubing. I used the propane torch to heat up and bend the tubing. I am cheap so I figured it's cheaper to screw up the PVC pipes than the actual metal tubing. The burned plastic smell was unbearable!...
HTH
Prasad
HTH
Prasad
