SignUp Now!Oh my god, just when you think ypu've seen it all. A Grand National with a bumper hitch and an Obama bumper sticker..... Couldn't have one without the other! Priceless.....View attachment 203556View attachment 203556View attachment 203557View attachment 203556View attachment 203557View attachment 203558 View attachment 203554View attachment 203554View attachment 203555
I just aw this thread. I didn't realize I was an early adopter of the rear frame brace 21
Scot sells the end brackets. You must supply the round or square tubing and have it welded.Doesn't Scott at GNS make this brace?
Conrad
When Chuck Leeper was having the brackets bent, we measured about 4-5 different frames. They were all different, and not a little. they were off about 1/2 inch total. It was decided that each person would be better off cutting them to fit each car.
This is how I did mine x members(fiberglass bumpers front and back) Camino uses the same hitch. Measured 1 - 1/2 in. back from the angle that bolts to the bottom frame bolts. Plasma cut the top 3/16 plate thats formed to the bottom of the frame stright accross and up. Clamped 1-1/2 x 2 x 1/8 thick, bolted the plate and sq tubing and welded . I also made end plates to tie everything in. Cost 1 old hitch and 56in. long 1-1/2 x 2 x 1/8 sq. tubing $25. and you dont see anything hanging below the bumper.For those that have added a cross member at the far rear of the frame, might you have a pic of where you located it, and details as to the tubing size, etc?
Frame is out of the car, and I'd like to be sure I don't add it, then have to cut it out!
TIA,![]()
