Well I am dropping the tranny tomorrow and putting a different one in. Well I want to do the rear main seal. I did a search on how to do this and it seems to me I have to raise the motor up which makes sense. I also read that if you drop the tranny, you can unbolt the pan and it falls out. So which one is correct? Also, do I have to pull the crossover pipe? By the way, I do have the stage poly motor mounts but I don't think that will bring the engine high enough.
TIA,
TIA,
