williambavila
William Avila (The Buick Guy)
- May 11, 2010
SignUp Now!Yes I know to stagger the seal I just forgot which way it goes. Thanks. what about arp main studd torque?View attachment 158961 Bottom picture.
Also, offset it a bit.
Notice in my picture how near the bottom of the picture the seal is up out of the channel, and on the upper side it's down in the channel. (hard to explain).
Where did you get 130 ft/lbs??? It's 100 ft/lbsInstalled the rear main seal and using oil on threads so 130ft lbs on the torque
looks like he's using ARP studs...that would be correct see above...factory bolt yes 100 is correctWhere did you get 130 ft/lbs??? It's 100 ft/lbs
Arp says 120#'s using oil on the threads of there studs.I am using there studs at 130 with oil. I am using there rod bolts with oil at 55#'s. Just a quick note that ARP has a tech line for anyone in this situation. I was unsure so I called It is best to do it right the first time than be like me and try it twice then do it right.lol 3rd engine in this carWhere did you get 130 ft/lbs??? It's 100 ft/lbs
The seals your talking about yes picture 2 is correct and they offset them to keep the ends from seaping oil. always offset a rearmain seal or 2 piece seal.Don't mean to thread jack , but why dose it need to be offset a bit? Also picture #2 is correct right?
Am i going to have an issue because i didnt offset mine? Im in the process of doin the rear main and head gasketsThe seals your talking about yes picture 2 is correct and they offset them to keep the ends from seaping oil. always offset a rearmain seal or 2 piece seal.
You should not have a issue. If your not to far into it you can take it back out and put another one in there but I have installed several that way. Its like asking what oil to run?? you will get a million answers.Am i going to have an issue because i didnt offset mine? Im in the process of doin the rear main and head gaskets
