rebuilt 200r4 bq trans and converter from 84 gn $400
tb3
elbows & a$$holes
bq trans with stock rebuild 6,000 miles ago. shift kit was also installed and shifts are nice and hard. 2600 stall. trans has no issues whatsoever. ready to go right in. case was blasted while it was apart, etc...
i can work with you on shipping. shouldn't be a problem to load on a crate and wrap it up tight.
located in st. louis
This is a good buy !!!!
also have a stock 200r4 bq from a wrecked 85 t thats sitting on the shelf. can't verify its performance, but fluid was not dirty when drained. the car had zero mods. i'll take $175 for it.
also have a 200r4 kcf that had been installed in a 86 gn. has brf valve body in it. cannot verify its performance either. take $200 for it
i can bring these to bowling green nats too
First in line for the BQ for 175.00 ;)
bq for 175 has sold.
buy the $400 bq, and get a spare 200r4 for free (pictured), the valve body, servo, front pump, and govenor have been removed. it has a oil pan with a drain plug on it.
buy the $400 bq, and you can have the kcf 200r4 (that has the brf valve body) for $150
are you being being funny or serious........? BTW, i have never seen the description BQ......what is that exactly....?
Yes, I bought the trannies. The BQ valve body is similar to the BRF valve bodies. They came in 84-85 Turbo Regals.
