I recently purchased a Cardone rebuilt PM and discovered a problem. The pump motor ran for more than 20 seconds.. I followed the diagnostic sticky (as well as the installation sticky). I removed the line from the MC to the pump and discovered the check control valve was missing. Will this cause the motor to run more than 20 seconds? Also I have heard thru the grapevine that most of the warranty issues with Cardone rebuilts are the check control valve- am I the first with a missing one???
If anyone has had this issue how did you resolve it eg did Cardone send a check control valve or did you have to return the entire unit?
Rick
Rick
