Still working on it, but heres a pic so far. Decided not to do a write up since there are so many on here already. I actually followed one to a tee so far. But a few differences i had was that most of them only secure by 2 bolts to the firewall. The Tallon one has a block that secures by 4. I called Butch and he recommends 4 for strength. See the picture, all you have to do is remove the plate and it bolts right in. I actually found the pedal and the cotter pin EASY and im 6ft about 230 with fairly large hands. The only issue i had was manuvering a bit as i lift quite a bit...other than that i got it by myself with a few trips in and out to line it up. I ended up changing the proportioning vavle and most of the lines were so rusted i ended up cutting them out and replacong them with new lines from Kirban=perfect fit. Still working on them, but heres a pic of it from the top...im satisfied so far.
