- 55# injectors
- Armstrong 93/110 chips
- Armstrong dual-pump fuel setup
- TE63 turbo, .85 hot side
- Powerstroke FMIC
- TBPT standard build tranny
- TBPT pro-torque 9.5" convertor
- self-built 3" exhaust
- external wastegate
I'm aiming for mid 10's to start.
So I should be avoiding non-roller cams?
My motor has 130k on it, should I even be looking at cams?
I haven't had a problem with it, trying to avoid a rebuild.
If compression is good then Leave it Alone!! Just get a timing chain.
It will runs 11's & thats all you get with no cage anyways. Just some good tires, & chip & tanslator & powerlogger & guages & etc.
OR
Look at ALL the threads with people wondering why their fresh build just broke & how many bad machine shops there are. Now if you truly want a 10 sec build then open the wallet & send motor to a good builder here, buy Champion heads or equal, get a properly built tranny, do the rear end, do the susp & brakes, add a cage & again OPEN the Wallet for tools to tune it or have it tuned & learn so you can maintain the engine & tune.
Speed costs $$$ so how much you want to spend??
Great AND honest advice.... Did he mention you'll have to OPEN YOUR WALLET????
