Reinforced upper rear perches
ttypewhite
Does anyone have any pictures of your upper perches in the rear reinforced? I need to get mine done and would like to see what others have done to get some ideas. I was told by TRZ that I need to get this done now that I have put Afco DA coil overs in the stock location. Without it, I will rip the stock perches out on a hard launch.
If you're referring to the control arm mounts, these pics will help. I installed h&r parts reinforcements upper and lower, great fit and they were cheaper than making them myself!
Driver's side upper and a lower, my phone isnt playing ball... if youre referring to the spring pockets, i would install a umi shock tower brace, that will tie the mounts together. Also, i plated the top of my spring mounts where my cage meets the frame so its pretty beefy back there
